Mark's Web Site
Date:  8-24-2016
Brief Description:  Re-assemble after painting interior
I spent some time getting all the pieces back on the fuselage that I removed for painting. The bushing took a little work to get back in place. I was able to remove all but one prior to paint, so for the one that was still installed I made sure to mask it well so no paint would get on it. I didn't remove it because it was so hard to remove; well it was just as hard to slide back into place. I really couldn't get any good contact with soft mallet or chuck of wood, so I ended up using a piece of wood with a rope and a mallet to hammer the rope much like a hammer slide. I just hammered on the open loop of the rope and the block of wood evenly tapped in the bushing. It's hard to explain, but it seemed to work. The others went on easy enough with a little boelube.
Wing spar bushings back in place
Air conditioner doors back on
Air conditioning
Air conditioning "on"
