Mark's Web Site
Date:  5-4-2016
Number of Hours:  1.00
Manual Reference:  29A-03
Brief Description:  Attach upper firewall (29A-03)
Work has been pretty busy, so I work on the plane when I get a chance. I've been bouncing around in this section, depending on what I have time to work on. Today I was able to get the upper fire wall attached with the help of Cyndi. Applying a small bead of fuel tank sealant with the home made caulk gun adapter and applied it just aft of the flange holes....not all the way to the flange corner. This way I only had a small amount squeeze out and the clecos didn't get too messy. It went pretty smooth without too much mess.
Seal and attach upper firewall
Upper fire wall rivetted into place
Applied a small bead of fule tank sealant just aft of rivet holes prior to attaching
