Mark's Web Site
Date:  4-27-2016
Number of Hours:  1.25
Manual Reference:  29A-05
Brief Description:  Strut attach angle - step 1 (29A-05)
Over the next 4 logs I will try to explain what worked out well for me on making the strut attach angle pieces. I had read where some had had a difficult time to get the holes to line up, but this worked out really well for me and the holes are perfect, so I'll show you how.
Step 1:
Cut the flange to the right length 1-5/8". A band saw would work best here, but since i don't have one I used my dremmel cut-off saw to get real close, then filed it down to size. The aluminum gets quite hot using a cut-off wheel.
Then I marked up the holes locations as directed on both sides. The key hole is the center one, so just make sure that is in the right place.
29A-05 dimensions and hole locations
cut to length and hole locations marked
marked holes locations on both sides
