Mark's Web Site
Date:  4-13-2016
Number of Hours:  3.00
Manual Reference:  29A-02
Brief Description:  Upper fuselage doubler (29A-02)
I read several logs and people had some challenges about holding the nutplate in place. I turned to the same conclusion to use needle nose vice grips, but I also added some left over fuel line as a spacer to try an apply a little more pressure on the wing of the nutplate. It worked well and was thin enough that it didn't interfere with the rivet. It was a little too soft, so by the end it was pretty much smashed. This was a practice piece that I had used to try out my flaring technique and worked well as a clamp spacer. Anyway that much is done. Don't forget the nutplates around the access cut-out. The directions call for AN426AD3-4, which work well for the nutplates that go through the firewall, but for the 2 nutplates on either side of the cut-out, I used AN426AD3-3.5. The directions don't specify, but they fit better.
Using some left over fuel line to help clamp the nut plates in place
nut plates installed on doubler
inside view of nut plates installed on doubler
