Mark's Web Site
Date:  4-2-2016
Number of Hours:  1.00
Manual Reference:  28-07
Brief Description:  Completed fuel lines (28-07)
Went around to each joint and final torqued the fittings with thread sealant and then added torque seal to indicate it was complete. I’m still waiting on the safety wire to complete the gascolator and also waiting for the fuel tank to finish up the last of the fuel line fittings into the tank. Once the gascolator is installed I’ll pressure check the system.
Next step I think I’ll build the rudder pedal assembly…just not install it until after the interior paint. Also, I think I may need to add the back turtle deck and the instrumentation shelf prior to painting. I’m just trying to get everything that needs interior paint installed, so I only have to do this one….knowing full well that I will miss something or I will have to touch things up later on. Plus I’m procrastinating getting all the painting supplies.
Added thread sealant and torque seal to each fitting
section 28 complete
section 28 complete
Added a slight bend to get this to come in straight
