Mark's Web Site
Date:  3-31-2016
Number of Hours:  1.00
Manual Reference:  28-05
Brief Description:  Apply thread sealant and torque seal at each joint
Went through and final assembled the fuel lines to each fitting that I could. I used thread sealant on the fittings and then applied torque seal to let me know which ones were complete. I didn’t assemble the fwd line to the gascolator, since I’m still waiting on the safety wire. Also I didn’t complete the fuel tank line since I still wanted to use it as a template for the return line.
Fuel line from pump attached
Not quite centerd in hole but enough clearance to line up with fitting
shut-off valve fuel lines attached
