Mark's Web Site
Date:  3-21-2016
Number of Hours:  3.00
Manual Reference:  28-04
Brief Description:  Long Fuel Line (F-1259E) Woes (28-04)
Well I had success on the first section of fuel line, so I moved on to the next section...the long fuel line from the fuel pump to the shut-off valve. I left me self some extra length and followed the s-bend laid out in the manual (28-04, rev 2, figure 3) exactly. This worked great for the previous section, but not for the long tube. The s-bend offset is correct, but the distance from the fuel pump end to the first bend is longer than needed. The trouble I ran into was that the fuel line 2nd part of the s-bend ran into the bulkhead before it cleared the fuel pump fitting, so I needed to shorten it up. The issue with the s-bend is: if you try to increase the bend angles to shorten the length, then it messes up the offset. If the s-bend had 90 deg angles, then you could easily make some slight changes without affecting the offset, but sine the drawing has ~45 deg angles then it dramatically affects the offset. I tried multiple times of sliding it down through all the holes, which was a challenge in itself, but could not get it to fit right. The smart thing to do would have been cut off the flare and re-create it ~1 inch back, but of course I figured it out way too late (the fuel line was already a pretzel with some extra twists). So, next I proceeded to order 16 more feet of 3/8 line and 16 feet of ΒΌ line (just in case). In the meantime I proceeded with the smaller sections of fuel line from the shut-off valve to the flow meter.
Update: I included an updated picture of a method that worked for me to get the bend correct. This worked well and I had no issues installing the long fuel line.
Lesson learned...don't follow the picture (figure 3)
Lonely fuel valve waiting for new fuel line...so moving on to next step
No issues creating the fuel line from the valve to the flow meter
