Mark's Web Site
Date:  2-18-2016
Manual Reference:  24-02
Brief Description:  Started riveting roll bar (24-02)
This went a lot smoother and started riveting the outside of the roll bar while it was clamped in place. I used my steel hole fixture around the mandrel to keep the rivet flush and clean (no burr pull through). A couple rivets I had to drill out, since it looked they were still not flush and smooth. I also torqued the bolts to attach the bases. I ended up buying a HF toque wrench that covered everything the small wrench couldn't.
Everything clamped again and ready to final drill the side holes (again)
With everything in place I went around the ouside and set all the CS4-4 rivets
Left base in place and torqued
