Mark's Web Site
Date:  12-28-2015
Manual Reference:  22-03
Brief Description:  F-1201L Bracket (22-03)
I measured the length of angle to cut and used a hack saw to cut to length. Then used my dremmel cut-off wheel to cut the angles. I also started the #30 holes with a #40 size then came back and final sized to #30. Then clecoed it in place to final drill the nut plate holes. After deburr and polish, I primed and attached the bracket. Everything lined up great.
Bracket fabricated and inplace for final drilling
drilled, and cleaned up and ready for prime
F-1201L bracket attached
