Mark's Web Site
Date:  12-21-2015
Manual Reference:  21-20
Brief Description:  Last touches on section 21 (21-20)
Benjamin, my son, helped push down on the pump bracket as I installed the rivets from underneath. The studs were a little challenging. Cyndi, my lovely wife was able to help with those, but only after I went to Lowes to get a 7/32 tall socket. The only way to get them installed was for me to hold the screw in place with driver in the drill and then she would crank the nut on with the socket wrench. Trying to rotate the screw only caused the Philips to slip out and cause damage to the screw head. In the end it all looks great, but I'm not sure what the studs will be used for...I guess we'll see. Anyway, I’m finally done with section 21. I'll ready ahead and call it a day.
Pump bracket installed
6 studs installed
6 studs installed
Bottom skin view
Bottom skin view
