Mark's Web Site
Date:  10-7-2015
Number of Hours:  1.00
Manual Reference:  21-02
Brief Description:  Bagage ribs to mid fuselage (21-02)
This was pretty tricky to get the compact rivet puller to work inside this tight space. Plus the holes were a little tight so I spent a lot of time trying to twist the reamer bit between my fingers to clear out the holes...man my fingers are sore. What worked best was to take the 12" #30 drill bit and work the hole a little until the rivets fit nice. The other technique was to use the wedge as much as possible in order to provide enough room to work the puller handles. Again a few scratches, but turned out well.
Tight space to work a rivet puller
Turned out well on the view from the otherside
Another view for the other side
