Mark's Web Site
Date:  9-5-2015
Number of Hours:  0.50
Manual Reference:  40-08
Brief Description:  Wing tip fiberglass (40-08)
Attaching it went well and I only had to push through the tapped holes with the clecos...no problem. Once it set up, that where the difficulty was. I removed all the clecos...some will need some clean-up to get them working properly again. With the clecos removed it did not budge...I thought I was hoping to have to leave it attached. I went ahead and drilled the remaining 2 holes. I ended up using my chip chaser to work it between the aluminum wing tip and the new fiberglass...that with a lot of prying on the formed wing tip and it eventually started to break free. I think I will try to release agent specific to fiberglass for the other wing tip. A little sanding and everything is ready to wire up and attach the light.
wing tip attached with fiberglass oozing out
picture from below, prior to wipping clean
Once removed and cleaned out the clay...turned out well, but a challenge to remove
