Mark's Web Site
Date:  7-11-2015
Manual Reference:  20-03
Brief Description:  Center Section Assembly (20-03)
During construction I failed to read the instructions correctly and counter sunk the holes indicated for AN470AD4-8 instead of just the holes assigned for AN426AD4-8. I made my first setup hole and just kept going. I looked ahead and it looks like the counter sunk rivets are in the area of the fuel tank so it can go right up to the center section assembly. I sent a note off to Vans to see if it would be acceptable to just use the AN426AD4 across all the holes. After a long winded question and explanation to Vans, I got the simple reply back from Ken Scott: "The CS rivets should be fine...", so I went forward with it. Since I would be using more rivets than was supplied, I had to order more. I ordered both AN426AD4-8 and 4-9, since the 4-8 looked like they may be a little on the short side.
Lesson learned, make sure to read and re-read the instructions. Someone suggested going through and highlighting the important notes before proceeding with a given section. I'll try to do that from now on.
Initial setup of counter sink, failed to pay attention that not all the holes are counter sunk
My note to Vans asking if it is acceptable to counter sink all the holes (red and green areas)
I captured a picture of what I had done and sent to Vans for advice
