Mark's Web Site
Date:  6-6-2015
Number of Hours:  5.00
Manual Reference:  18-05
Brief Description:  Right Flaperon assembly (18-05)
The technique to drill the holes worked nicely and lined up very well. I started with the punch to mark the holes, then followed with a 3/32 drill bit in the drill press (using the vice clamp to hold it level), then finished drilled with the #30. Everything primed and skeleton assembled.
Right flaperon couter balance drilled and installed
bracket installed
bracket installed
Counterbalance complete
