Mark's Web Site
Date:  5-19-2015
Number of Hours:  1.00
Manual Reference:  18-03
Brief Description:  Rivet outboard nose rib to counterbalance (18-03)
Deburred the holes through the stainless steel counterbalance and primed the area locally to mount the two nose ribs. Everything looks good so far.
Added Info: Make sure the orientation is right for all pieces in the section. As I found out later on when building the right flaperon assembly, it's easy to make mistakes. The left is easier since it shows the right orientation in the pictures...the right is a mirror image.
Attached nose rib to counterbalance
Most outboard rib
Most outboard rib
Inboard rib attached
