Mark's Web Site
Date:  1-8-2015
Number of Hours:  1.00
Manual Reference:  40-02
Brief Description:  Finsh access hole for right wing tip light (40-02)
After the hole was roughed in with cut-off wheel I followed up with the sanding wheel to bring it to final size. The size of the opening didn't have to be perfect, but I was working on my technique in prep for the landing light opening. It worked out well and I'm pleased with the results.
Final sizing the access hole for the right wing tip light
Cleaning up the edges with fine grit sanding drum
Access hole turned out well
