Mark's Web Site
Date:  1-2-2015
Number of Hours:  6.00
Manual Reference:  17-05
Brief Description:  Left wing tip attachment (17-05)
I spent some time constructing a card stock triangle for each angle called out in the manual. Then laid the wing tip down on the kitchen tabled and proceeded to bend each tab to the prescribed angle. It fit nicely once I started adding clecos. I'm impressed with the way this skin was designed and lines up. Although there are a lot of open gaps where the skins meet up, but I've seen the same on all the other RV12's. Overall I was pleased with the results. I was a little nervous when I first started attaching the skin, because a bunch of holes were not even close to lining up, but as I worked my way around everything started to line up perfectly.
Wing tip edge angles set and ready for deburr and prep
Trial fit went well and now rivetted in place
Following the angles in the manual everything lined up nicely
