Mark's Web Site
Date:  1-1-2015
Number of Hours:  3.00
Manual Reference:  17-05
Brief Description:  Wing tip edge rib channels (17-05)
I spent some time fluting the edge ribs just the right amount to get it to follow the curve in the wing tip. Everything fit up nicely as individual pieces, but when I put the fwd and aft edge ribs together, they didn't fit very nicely. Some older videos show the aft edge on the outside for the fwd edge and it seems to fit nicely that way, but the instructions show it the other way around, which looks better. I had to do a little grinding to get everything to fit up nicely.
I had to girind down the tab a little to get it to fit into the fwd edge channel
I also had to grind down the spar tip a little to fit nicely into the channel
Edges channels clecoed in place and ready to rivet
