Mark's Web Site
Date:  10-6-2014
Number of Hours:  1.00
Manual Reference:  15-02
Brief Description:  Wing rib flange tab removal process (15-02)
I tried tin snips on the first rib, but ended up with a little bend in the flange are, which I had to try and ben out. It wasn't bad, but figured there had to be a better way. I could always just file it down, but that would take a while. So I tried this three step process and it's worked out well.
1. First I grind down the bent corner of the flange until it's thin enough to bend
2. Then I bend it back and forth until it falls off
3. I take the grinder to smooth it out and shape it into a continuous surface.
The trick is to take it slow and be very careful not to let the grinder get away from you...just light cuts.
1. carefully grind down the bend on the tab
2. once thin enough bend back and forth to remove
3. carefully smooth out and shape
