Mark's Web Site
Date:  3-13-2014
Number of Hours:  3.00
Manual Reference:  09-04
Brief Description:  Drill nut plate holes and hinge brakets (09-04)
Completed all the steel hole drilling for the upper and lower horns and for the balance arm. The new 3/16 cobalt drill bits worked great, then I just followed up with the #12 drill bit I had. Next moved on to creating the holes for the nut plates for the horns. This went well, but I had little trouble later on when I had to set the rivets. Since I had positioned them so close to the flange radius (because this is what it looked like in the manual picture), it created a little crimp or dent in the edge next to the rivet. I now wished I had rotated them more to keep it away from the edge.
Locate and drill nut plate rivet holes
Counter sink newly drilled holes
Set rivets for nut plates on the hinge brackets
