Mark's Web Site
Date:  1-9-2014
Manual Reference:  06-05
Brief Description:  Rivet spar caps to rear spar (06-05)
Actually made a little progress today. Pulled my first rivets for the rear spar. The pneumatic puller works great, but not good next to the flange, so I switched to the hand puller...ouch, make sure to wear gloves. Also go to try out the wedge, which worked great, just make sure to set up a shield since the space is tight up against the spar flange.
Also set the small flush rivets at the lower spar cap, but one of them was sitting flat, so I drilled it out and tried it again (very carefully this time). Worked great. Still need to get the hang of squeezing rivets.
Using the pneumatic puller...sweet
Using the hand puller with wedge...not so sweet
Wedge works fairly well, just the puller hurts (wear gloves)
