Brief Description: Finished up interior & prepared to close the wing
Grounded the fuel tank to the frame, mounted the strobe to the wing tip, Inspected the interior of the wing for any uncompleted tasks - checking both the builders manual and upgrade manual. Thourghly vaccumed the interior of the wing and applied corrosion protection to all parts that contact each other. Finished riveting the wing skin stiffeners.
After one more inspection of the interior, checking the torque on all bolts, the top and leading edge skin was reassembled and clecoed in place.
I did find I had installed the wrong hinge on the airleron so replace that with MS20257-5 and trial fit the aileron and flap.
