Brief Description: Assembling and Sealing the Tank (LH)
Wet-riveted the T-405 tank attach angle and T-410 reinforcing plates in place on the end ribs.
Wet-riveted nutplates around reinforcement ring on inboard rib and covered nutplates with sealant. Made fillets of sealant at the joints of all mating surfaces of access panel reinforcement ring, T-405 and T-710.
Covered the aft tooling hole on the outboard T-703 end rib plugging in an AN470AD6 rivet and proseal.
