Miguel Vidal RV-8
Date:  8-25-2014
Number of Hours:  1.20
Manual Reference:  8s7-1r11 7-5
Brief Description:  Fitting Attach Angles to Spar and Baffle (RH)
Used a square angle to find correct alignment of z-brackets in relation to the spar and holes.
Match-drilled #12 all holes in z-bracket using main spar as guide (match-drilled from inside the wing and between main wing ribs).
Unclecoed, deburred, and cleaned all holes made in z-brackets. Cleaned and deburred all guide holes in spar as well.
Clecoed all the z-brackets again from the inside of the wing to mount RH Fuel Tank Assembly.
Secured Fuel Tank Assembly using clecos to the corresponding Fuel Tank-to-Spar attachment nutplates.
Match-drilled #30 the holes in the inboard rib to the Fuel Tank Baffle and the inboard z-bracket, and secured with clecos to hold the Rib and the Baffle in place.
Aligned z-brackets using a square and tightened one hole with a bolt and nut
Once aligned and secured, drilled and placed clecos to secure z-brackets
