Temporarily placed the outboard sender plate/wire assembly in its fuel tank rib bay, and installed the modified snap bushings in the ribs. Routed the wire from the outboard sender plate through the snap bushings, and installed the vent line through the snap bushings. Rotated the snap bushings so that the sender wire wrapped around the vent line approximately following recommendations of DWG OP-7, Fuel Tank Top View.
Temporarily placed the inboard tank end rib/bulkhead coonector/wire assembly in the end rib bay. Routed the wire around the vent line and through the snap bushing to the inboard sender plate.
