Miguel Vidal RV-8
Date:  10-31-2013
Number of Hours:  1.20
Manual Reference:  Dynon Pitot (3-2)
Brief Description:  Pitot/AOA Probe Plumbing
Cut the 3/16" dia. Pitot and AOA aluminum tubes coming out of the Dynon AOA/Pitot Probe to about 7 inches in length to fit inside the wing.
Practised flaring the tubes using the ROLO-FLAIR 37-degree flaring tool on scrap 3/16" aluminum tubes.
Installed AN fittings and final-flared AOA/Pitot tubing.
Carefully taped fittings, heating system wiring, and probe, and primed the two 3/16" tubes to prevent corrosion of the aluminum.
Installed the remaining AN and NPT fittings and adaptors from SafeAir1 to torque values and placed a dab of yellow Torque Seal.
Pitot Tube fittings are torque-sealed at 60 in-Lb.
The four oval head phillips machine screws that will hold the Pitot/AOA Probe to the Gretz Aero mast mount have the following specifications:
Screw size: M5-.80x#10
Purchased and available at Lowe's. SKU: 008236711431
*UPDATE*
Dynon released a Technical Service Bulletin on May 6, 2014 (Revised Oct. 10, 2014) regarding a degraded airspeed indications while the heated probe was in operation.
Dynon determined a total recall for affected heated probes, which were sold before October 2014, and/or have serial numbers lower than S/N 6000.
This SB was complied with a new Heated Pitot/AOA Probe sent from Dynon on Jan. 02, 2015.
Entries for new probe logged.
Cut the aluminum pressure tubes to about 7 inches long
Tubes flared and AN fittings installed
AN and NPT fittings from SafeAir1 with Torque Seal
