Miguel Vidal RV-8
Date:  2-5-2013
Number of Hours:  1.50
Manual Reference:  8s6r12 (6-13)
Brief Description:  Finishing the Elevators
Before final instalation of the E-617 (RH) Elevator Fiberglass tip, the E-714 (RH) Elevator Lead Counterweight needed to be measured and trimmed according to minimum measurement requirements in DWG 5 in order to compensate for the overweight and overbalance of the counterweight horn
A pair of relief holes where drilled on top and bottom to avoid sharp corners after the cut.
Regular hacksaw and a gallon of WD-40 lubricant were used to make the cuts.
Primed the newly exposed area of the lead counterweight after the WD-40 was completely wiped off.
Measured area to be removed. Relief holes drilled
Removing lead with a hacksaw
Final result after primer
