Miguel Vidal RV-8
Date:  2-14-2013
Number of Hours:  1.20
Manual Reference:  8s6r12 (6-13)
Brief Description:  Working with Fiberglass Tips
Measured and drilled top & bottom holes on HS-801PP LH & RH skins for CS4-4 blind rivets that will attach HS-615 LH & RH molded fiberglass tips.
Match drilled new holes to fiberglass tips.
Minimum required pitch & edge distances taken from MIL-R-47196A.
Match drilling holes after measuring proper distances
Installing HS-615 fiberglass tips
