Miguel Vidal RV-8
Date:  6-12-2012
Number of Hours:  0.50
Manual Reference:  8s6r12 (6-3)
Brief Description:  Riveting Horizontal Stabilizer
Bolted the HS-411PP center bearing assembly to RSA according to bolt and nut torque specifications of 20-25 in-lb torque. Used 23 in-lb of torque. Decided not to use torque lock (Locktite) to avoid damaging the the nylon plastic inside the nut stops.
Used red neon-colored nail polish for witness marks as "torque seal".
*June 20, 2012 EDIT: "Torque Seal" color changed to bright neon orange nail polish for better visualization (not pictured)
HS-411PP assembly with witness marks
HS-411PP assembly with witness marks (back)
