Miguel Vidal RV-8
Date:  6-7-2012
Number of Hours:  1.60
Manual Reference:  8s6r12 (6-3)
Brief Description:  Preparing Horizontal Stabilizer Pts for Assy-Skins
Peeled inner protective blue vinyl from for HS-801PP skins.
Sanded inside surfaces with 400 grit sandpaper, washed clean with Klean Strip Odorless Mineral Spirits.
Cleaned off excess Mineral Spirits with dry rag. Air dry for 20 min.
Primed inner surfaces with Krylon Dual Paint+Primer: First coat air dry for 1 hr,
Sprayed a total of 3 Coats.
Sanding skins
Sanding skins
Priming Skins
Priming Skins
Finished surface
Finished surface
