Miguel Vidal RV-8
Date:  3-24-2012
Number of Hours:  2.90
Manual Reference:  8s6r12 (6-2/-3)
Brief Description:  Drilling the Horizontal Stabilizer (LH)
Drilled HS-405 rib to HS-801PP skin.
Drilled HS-405 rib to HS-702 FSA to HS-810-1 and HS-814-1 reinforcement angles to HS-404 nose rib.
Marked and drilled #40 the hole locations on fwd side of fwd flange of HS-405 rib. Attached FSA to HS-404 nose rib with proper edge distance and clearances according to DWG 3.
Used these holes as guide to drill fwd flange of HS-405 rib.
Match drilled all remaining holes attaching HS-801PP skin. Marked all match-drilled holes with green Sharpie marker.
Match drilling holes HS-810-1 & HS-814-1 to HS-702 to HS-405
HS-405 FWD flange hole detail
All HS-810PP skin match-drilled (both sides)
