Miguel Vidal RV-8
Date:  3-6-2012
Number of Hours:  1.50
Manual Reference:  8s6r12 (6-1/-2)
Brief Description:  Front Spar Assembly
Labeled LEFT/RIGHT for Front Spar Assembly (FSR) according to HS-810-1 and HS-814-1 reinforcement angle bars orientation to HS-702 front spars.
Drilled and match drilled (existing holes) inboard of HS-404 & HS-405 attach points and HS-810-1 & HS-814-1 bend lines.
Marked with Sharpie the location for further reinstallation of HS-810-1 and HS-814-1 to HS-404 & HS-405.
Measured, marked, and prepared both sides of HS-810-1 and HS-814-1 for tampering and rounding off edges.
Drill/match drill center holes
FSA
FSA
Tamper markings detail
