Miguel Vidal RV-8
Date:  3-5-2012
Number of Hours:  3.50
Manual Reference:  8s6r12 (6-1)
Brief Description:  Rear Spar Assembly
Final drilled HS-603PP to HS-609PP assembly to #30.
Final drilled HS-412PP and HS-413PP to Rear Spar Assembly to #30.
Match-drilled attach holes in VA-146 bearing and HS-411APP bracket.
Deburred all HS-411 bearing assembly holes and bracket attach holes (both sides).
Riveted HS-411 bearing assembly together.
Final enlarged & match-drilled HS-411 bearing assembly and respective RSA bracket holes to #12.
All items clecoed in RSA and properly marked in position with blue Sharpie.
Preparing for final drilling
Match drilled HS-411 bearing assy.
HS-411 bearing assy. ready
