Miguel Vidal RV-8
Date:  3-14-2019
Number of Hours:  6.00
Manual Reference:  8s8PP-1r1 (8-1&2)
Brief Description:  Firewall
Began fuselage construction.
Located firewall parts and removed protective vynil.
Began putting together the Firewall frame according to DWG 60. Match-drilled holes and deburred edges.
Final-drilled holes according to construction manual.
Deburred all holes in the stainless steel firewall.
Located, separated, labeled, and deburred Firewall gussets, spacers, and backing plates
Clecoed together firewall frame
Match-drilled and final-drilled firewall holes
