Brief Description: Mid Fuselage Skins and Structure
Repeated the roll process now with the LH F-823-1 Mid Side Skin. Way easier this time around.
Clecoed the Seat Rib Subassembly to the F-804 Center Section Assy, where they join at the Center Section Assy's bottom flanges, and the F-814E-L-1 & R-1 Seat Ramp Supports. Final-drill #30 the holes common between the Seat Ramp Supports and the Inboard Seat Rib assys. Used a fly cutter to cut a hole in the F-815A-R-1, and the RH F-823-1 Mid Side Skin. Used DWG 69 for the pilot hole location and size. Deburred the edges of these two holes. Clecoed the F-815A-L-1 & R-1 Fwd Outboard Seat Ribs, F-815B-L-1 & R-1 Aft Outboard Seat Ribs, and the F-815C-L-1 & R-1 Outboard Seat Rib Angles to the Seat Rib Assy.
Fly cutting the hole for the NACA vent duct on F-815A-R-1
