Continued work on Seat Rib Subassembly. From Construction Manual: Cleco the F-806C-1 & D-1 Bars, the two F-806G-1 Seat Belt Attach Lugs, and the F-806F-L-1 & -R-1 Gussets to the bulkhead (See “F-806B-1 Rear Spar Attach Bulkhead Assembly”, DWG 65). Rivet all parts to the bulkhead using rivet call outs in F-806B-1 Rear Spar Attach Bulkhead Assembly Rivets view on DWG 65. Rivet nutplates to the F-814C-L-1 & -R-1 Inboard Seat Rib Angles. Cleco the F-814HPPX Fwd Seat Belt Anchor, and the F-814J Fwd Seat Belt / Vent Anchor to the F-814G-1 Seat Belt Anchor, and rivet them together. Cleco the right Seat Belt Anchor Assembly to the F-814A-R-1 Fwd Inboard Seat Rib.
