Idler Bracket Installation Installed the F-8118 brackets to the aft side of LH & RH F-802H Gear Leg Aft Angles. Match-drilled missing hole in F-8118 brackets. Deburred primed, and installed the idler brackets in position. Torqued AN3 bolts to 35 in/Lb. No pics
