Began fuselage construction. Located firewall parts and removed protective vynil.
Began putting together the Firewall frame according to DWG 60. Match-drilled holes and deburred edges. Final-drilled holes according to construction manual. Deburred all holes in the stainless steel firewall.
Located, separated, labeled, and deburred Firewall gussets, spacers, and backing plates
