Miguel Vidal RV-8
Date:  1-23-2019
Number of Hours:  1.50
Manual Reference:  8s7-1r11 (7-10)
Brief Description:  Installing the Flap Brace and Aileron Gap Fairings
I decided to test fit everything before final riveting the aileron gap fairing to the rear spar, and noticed that an edge in the outboard end of the W-724 Aileron Gap Fairing would interfere with a rivet in LH W-414 Outboard Aileron Hinge (pic 1).
So I took both gap fairing off and trimmed that edge .145" less to clear a gap with that particular rivet head. Since RH is basically a mirror of the LH, I took care of RH gap fairing as well. Then came deburring, and priming both parts before getting them ready to rivet in place.
Aileron gap fairing test fit and interference with outboard aileron hinge
Aileron gap fairing with pilot hole drilled for trimming
