Miguel Vidal RV-8
Date:  1-12-2016
Number of Hours:  0.70
Manual Reference:  Duckworks HID 24-6
Brief Description:  Wire, Switches, Fuses, and Connectors (RH)
Worked on electrical wiring in RH wing.
Drilled holes and installed nylon adel clamps to outboardmost RH LE rib to hold Duckworks HID LE Landing Light ballast wires: Drilled two #19 holes 1.0" inboard from LE skin and 1.0" distance (front hole) from stiffening crease and (aft hole) from main front spar.
Used rivets to secure nylon adel clamps in place.
Pop riveting nylon adel clamps to secure HID Light cables in outboardmost LE rib
