Miguel Vidal RV-8
Date:  10-9-2015
Number of Hours:  2.50
Manual Reference:  Duckworks HID 24-5
Brief Description:  Rivet Nutplates to Retaining Strip (RH)
Dimpled holes in retaining strip to accept nutplates and flush rivets.
Enlarged the screw holes in the strips using the 5/32" drill bit.
Deburred, cleaned, and primed strips.
Drilled out the screw holes in the plexiglass with a 5/31" drill bit.
Countersunk the plexi holes for the dimples in the skin to fit.
Riveted the 6-32 nutplates to strips using AN426AD3-3.5 flush rivets.
Attached strips to inside of lens using thin two-sided tape.
Dimpling retaining strip for nutplate rivets
Countersinking holes for screw dimples in Leading Edge skin
Riveting nutplates to retaining strip
