Miguel Vidal RV-8
Date:  10-14-2015
Manual Reference:  Duckworks HID 24-5
Brief Description:  Working with Plexiglass Lens (RH)
Trimmed a little plexi off of the bottom edge of the lens to help prevent interference between lens and mount.
Trimmed the corners of the Retainer strip to improve fit in the top curve of the lens.
Installed protective foam strip inside leading edge cutout sides to protect plexiglass
Mounted HID light assembly and final installed plexiglass lens to Leading Edge, using 6 6-32x3/8 100° Stainless Screw from Duckworks.
Fitting retainer strip for screw installation
Installing protective foam strip
RH Leading Edge Landing Light complete
