Miguel Vidal RV-8
Date:  12-21-2015
Number of Hours:  1.00
Manual Reference:  8s7-1r11 (7-12)
Brief Description:  Attaching Ailerons to the Wing (LH&RH)
Began assembling both WD421L & WD421R aileron bellcranks using DWG 15A as a guide.
Discovered a slight binding in the bellcrank brass bushing, so some sanding to the outside and some reaming on the inside, as well as to the WD421 counterpart were required until no binding was felt.
Assembling WD421 bellcranks
Some sanding was required to eliminate binding feeling
