Miguel Vidal RV-8
Date:  1-20-2016
Number of Hours:  1.20
Manual Reference:  8s7-1r11 (7-12)
Brief Description:  Attaching Ailerons to the Wing (LH&RH)
Assembled WD-421 LH & RH bellcranks as shown on DWG 15A. Tested fit with the AN4 bolt.
Sanded brass bushing to fit dimension drawn on DWG 15A, and slightly deburred edges.
Lubricated the brass bushings with LPS 2 Heavy-Duty Lubricant before final installation on wing.
Deburring sharp edges
Measuring bushing dimensions
Final test fit
Final test fit
