Miguel Vidal RV-8
Date:  8-22-2014
Number of Hours:  0.80
Manual Reference:  Duckworks HID 24-3
Brief Description:  Installing the Reflector Mount (RH)
Installed RH Ballast, igniter, and cables on Reflector Mount.
Fitted Reflector Mount into the LE bay and attached to the ribs using 4 washers and flathead 10-32 philips screws.
Adjustment would later be accomplished when wings are mounted and airplane is in level (approach) flight configuration.
Set the assembly aside for plexyglass installation and before final mounting on Main Spar.
Reflector mount, HID lamp, and ballast installed
Lamp installed on Reflector Mount inside Leading Edge
