Miguel Vidal RV-8
Date:  6-6-2014
Number of Hours:  0.50
Manual Reference:  8s7-1r11 (7-6)
Brief Description:  Fuel Tanks Return System (LH)
Drilled a hole in the LH fuel tank end inboard rib to install the Fuel Return Line fitting if ever required for the use of a fuel injected engine with unused, high-pressure fuel return system to fuel tank.
Hole and fitting will be the same as that used for the flop tube assembly.
Drilled hole for Fuel return fitting
