Miguel Vidal RV-8
Date:  9-2-2014
Number of Hours:  2.50
Manual Reference:  8s7-1r11 (7-6)
Brief Description:  Fuel Tank Final Preparations (RH)
Removed the T-701 fuel tank skin and ribs. Final drilled #30 all holes attaching the T-702 Fuel Tank Baffle to each of the T-712 Fuel Tank Attach Z-Brackets.
Removed the baffle and ribs. Clecoed all the fuel tank assembly and match-drilled the holes in the tank skin to the tank's ribs and baffle.
Countersunk spanwise rows of holes in the T-701 tank skin.
Drilled the spar attachment screw holes and the W-423 screw holes to final size using a #19 drill bit
Marked all ribs position and disassembled the fuel tank.
Match-drilling baffle holes to z-brackets below
Match-drilling holes in skin and ribs
Fuel tank skin to baffle holes countersunk
