Miguel Vidal RV-8
Date:  7-1-2014
Number of Hours:  0.80
Manual Reference:  Duckworks HID 24-6
Brief Description:  Wire, Switches, Fuses, and Connectors (LH)
Worked on electrical wiring in LH wing.
Drilled holes and installed nylon adel clamps to outboard LH LE rib to hold duckworks HID LE landing light ballast wires: Drilled two #19 holes 1.0" inboard from LE skin and 1.0" distance (front hole) from stiffening crease and (aft hole) from main front spar.
Drilled holes for nylon Adel Clamps
Nylon clamps installed and wire routed
LH Landing light wiring set.
