Miguel Vidal RV-8
Date:  6-16-2014
Number of Hours:  4.40
Manual Reference:  8s7-1r11 (7-7)
Brief Description:  Assembling and Sealing the Tank (LH)
Riveted and sealed filler neck flange and fuel vent line clip. Encapsuled rivets and clip.
Fay sealed with 100% clecos outboardand inboard ribs and placed proseal fillet on inboard side mating edge. Fabricated and installed fuel return line out of 3/8" OD x 17.25" aluminum tube and flared one end.
Modified the 6D AN washer/spacer to fit with the flop tube's anti-rotation bracket.
Fay sealed with 100% clecos inboard rib.
Fabricated and installed the first part of the diagonal anti-hangup bracket from stiffner to second inboard rib to avoid flop tube from getting caught in that side of the bay.
Riveted and encapsulated Fuel Filler Neck and vent line clip
Installed outboard rib with proseal and 100% clecos
Diagonal anti-hangup guide
