Miguel Vidal RV-8
Date:  6-5-2014
Number of Hours:  3.50
Manual Reference:  8s7-1r11 (7-7)
Brief Description:  Assembling and Sealing the Tank (LH)
Installed and prosealed reinforcement plate to LH Tank outboard and inboard ribs.
Covered the aft tooling holes in the outboard T-703 end rib plugging an AN470AD6 rivet.
Fay installed fuel tank filler neck to skin with 100% clecos in place.
Deburred nylon washer for sender plate mounting screws.
Installed reinforcement plates on inboard and outboard ribs.
Applied proseal and installed Fuel Filler neck
Plugged outboard rib's tooling hole using a 470AD6 rivet and proseal
